Help Send Text
felix822
Member
When typing a text message in landscape mode, do always have to press menu and then send or is there a send shortcut on the keyboard? Thanks.
In Handcent, you can set the enter key to be a substitute for the send key. Or you can hit the back key and then hit send.
To configure this in handcent, menu>settings>send message settings>shortcut key to send>enter
AFAIK, you can't set this in the default messaging app, but that one is slow and horrible, so I wouldn't use it, anyway.
