Help send to voicemail issue
Crashumbc
Android Expert
Ok so when I first got my dinc. someone on here showed a awesome trick, by setting about a contact with the number as "Unavailable" you are able to set the contact to go directly to VM so you don't have to worry about those calls...
Either VZW as changed something or it doesn't work on 2.2...
Anyone do this or have ideas on how to make this work again?
'tis easy. Go to the Contact, scroll down a bit and just above Edit is Send to voicemail, tap the down arrow at the right side of the screen and then tap OK. You're done.
Unfortunately, I've found that, but it still doesn't work :(
If anyone has it working what are you putting in for the number? currently I have "Unavailable" (without quotes)
jwm1986, glad I could help.
Crashumbc, I don't know what you are talking about. Send to voicemail is either on or off for any particular contact, there is no number. When a contact is set to be sent to voicemail calls you, they will be told that you are "unavailable" and be sent directly to voicemail. Can you post a screen shot?
Ok re-reading my OP I wasn't real clear.
I'm talking about calls with no phone num# displayed(either because its blocked or more likely a marketing call)
If you look at the phone when you receive a call it says "Unavailable" for the phone#
Before 2.2 I was able to set up single contact with the purpose of sending these straight to VM by putting in "Unavailable" for the phone # and checking the to VM button.
This no longer works :/
