Sending a Picture Not Working?
Optimus_User
Every time I try to send a picture to someone via MMS, it gets stuck on perpetual "sending." As in, it never sends. Why?
I'm on ZVD, but it did this on ZVB too. I'm running ld's stock, debloated ROM and his speed kernel.
And also on a side note.. I gave this problem off and on sending with goSMS.. So just to be on the safe side I always use the stock messaging app and rarely have the issue..
Just for future Reference if you download a message app you must keep the stock one enabled or you won't send or receive pictures. Just disable the notifications in the stock app.
That's what I do, well I think.. Is there a way to check that its enabled?
