Help Sending and receiving mms messages?
RocketFoot
Can anyone give me some pointers on sending and receiving pictures, animated text messages, videos...etc.
Do I need an app to do it? Or will the factory app work? Any app recommendations?
Sorry, I am new to the whole Android thing! :)
I downloaded Handcent...but i saw that there is a paid upgrade for messaging or something? Maybe I'll try GO SMS.
The free version of Handcent works just fine for me. It's ad-supported, but the ads are only in the configuration screens, bless them.
New to Android phone. I downloaded GO SMS but how come I don't see the app along with the others? I can use it if I go to the Market app and look at installed apps. Sorry for such a novice question, still trying to figure things out here. Having problems receiving MMS through messaging and thought GO SMS would help me out. Appreciate any help I can get. Thanks.
No, it appears that there is a know issue with receiving MMS...hopefully they will get it fixed. It can't hurt to call VM Cust Service and start a ticket!
As far as apps, you have to go to your installed apps page and press and hold the goSMS icon and the screen will change so you can let it go on your home page. Be sure to change notifications on your factory messaging or you'll get to notifications! You can do the same for the factory messaging app...press and hold then drag and drop to the garbage can. It doesn't delete, it goes to your installed app's page! Hope this helps!
