natorade93
is it possible to send mms over wifi? i was always under the impression that you cant, all the research iv done says no, and it wouldnt work on my htc hero, but as it seams on my evo 3d and my moms samsung intercept its allowing it. 3g turned off, wifi on, and pictures are sending.
in my previous trys, it wud work that if 3g and wifi were on the wifi icon covers the 3g and when sending a picture the 3g would pop up next to the wifi icon and dissapear after sending (showing 3g is needed for sending). but recently this hasnt been happening. im sending pictures when wifis on and 3gs off and its not turning 3g on and 3g doesnt pop up. could it be turning on 3g in the background without notifying us? and if so is this new because it didnt used to do this on my hero? its also doing this for visual voicemail (which also requires 3g)
