stevcha Android Expert Dec 6, 2010 #1 Is there a way to disable the send text icon and just use the enter key on the keyboard? Thanks
lordofthereef Android Expert Dec 6, 2010 #2 I don't believe so. There might be a setting in handcent sms but I haven't found one.
T trader914 Well-Known Member Dec 6, 2010 #3 In the stock SMS, I don't know. I use the free app called chompSMS and it is 1000 times better and you can set it to the way you want.
stevcha Android Expert Dec 6, 2010 #4 Just installed chompSMS and that did the trick. So much better! Thanks!!!
T trader914 Well-Known Member Dec 6, 2010 #5 Play aropund with the chompsms - it is very very customizable....
