sending to sd card? and see ya bionic...
aaronmach1
its been good but its my last day with the bionic. My new razzr hd maxx is coming to my house today. After 3 replacements witht the bionic due to the headphone jack failing and now for the second time the earpeice speaker went junk.
Now im going to give my bionic to my daughter to play games on. i hope.... i want to wipe the phone and download a bunch of games on it before i take service off it tonight. How can i save the games to just the sd card? and when i look right now i cannot find any of the current games i have or apps. Are they hidden or somthing? last night i downloaded one of her games to see where it saves and couldnt find it internal or on the sd.
Lastly, will i be able to download games on my razzr maxx hd and transfer them via computer to the bionic sd card for her to play? If so how, if i cannot see where the games are stored lol. thanks
You should be able to download to the Bionic using a Wi-Fi connection.
I have an activated Bionic and a deactivated Droid X. Both are recognized at Play Store. I apply updates to each one every day from Play Store. The Droid X uses Wi-Fi for the downloads.
I have not tried this with a deactivated Bionic.
... Thom
As long as you have the same Google account activated on the Bionic, you can either go to the play store on a computer browser for that app and install to the device, or you can go to the Play Store app on the Bionic, go to menu->my apps, swipe to "All" to see all of the apps on your account - or you can search for the app and install it to the Bionic. You only have to pay for an app once, on as many devices as you have activate on your Google account.
to be clear, i am transferring my service to the new phone tonight. The bionic i want games on will not have and service for calls, texts data etc. It can still get on wifi??? how do i do this? to this day ive never been on wifi with it. Im at work right now and it wont connect to our wifi it shows it has signal to.
Yes, it needs to connect via wifi. Yes, an inactive bionic will be allowed to connect via wifi. If you wipe the device the first setup step will be to activate the phone. Go back to the first screen you see and tap the four corners of the display in this order: top left,top right, bottom right, and bottom left. The top taps will be just under the status bar. This will skip the setup and bring you straight home. From there you can connect to a wifi access point and then enable your google account.
