Root Sense 5 Port - Android 4.1.2 - working Bluetooth, Face Unlock
Loaded R24 earlier today at work running fine connected to wifi. Now at home I noticed it keeps getting authentication error. Anyone else having this issue? t/u
Tried reboot no good, turned off wifi a 2nd time and back on and it is working, very strang but great rom.
I'm on an older version (r17) but I haven't seen a change log addressing the mms photo compression so I thought I'd ask. I have my limit set to 5mb but when I send a photo via messages app it still shows my photos being compressed to around 40k. I tried the 3mb setting too and it doesn't seem to change anything. Is this just normal or is my device not working as it should.
I haven't updated to r24 because so far it seems everything I need is working fine on r17. I don't mind updating if I have to.
Thanks for any help!
Not sure where I commented on this, but this isn't something I broke, so unfortunately I know nothing about fixing it. The project is open though, so if anyone else finds the fix, I can add you to svn to commit it.
Wait, arc reactor works with this Rom?
I didn't realize different kernels would run. :o
Yinz out did yourselves seriously. Been going through the motions, using my daily apps and functions, everything works great. Even got 4G and it's working fine. WiFi works great, no issues at all.
My GPS locks quick and it's close enough for state work. ;)
I need to try and send an mms message, haven't done that yet.
Everything works great.
Arc runs perfectly as well.
Rootlinux ,Bullerproof kernel works great also. Love double tap to wake. Laughed when I heard lg g2 talking up their double tap to wake when wehave had it for a few months.
Tried to download Bulletproof, but it looks like it may have been pulled, link does not work. Can some one link it or pm it to me please?
Looks like a server maintenance thing -
http://forum.xda-developers.com/showthread.php?t=2181243
Idk if I'm the only one having this issue or not but every time I reboot, the Rom never loads. First boot after flashing is fine I do all my signing in use the Rom everything works and is absolutely great. Till I reboot then it just sits on the HTC one boot screen and never comes back. I've tried it after restoring app backups and not I've tried after letting it sit for a while or just after flashing and doesn't make a difference. I did the suggested wipe method for twrp with kk compatibility then reflashed and I've even fastboot flashed the original twrp 2.6.3 and reflashed and all with no luck. The other roms I use work fine reboot fine its only these sense5 roms. Its not only yours its yankees too....Idk what else to try..
If anyone has general Sense 5 questions, you can ask at -
http://androidforums.com/showthread.php?t=706745
Don't get into rooting or this rom, just features - otherwise people will get confused and staff will move your posts back here.
Just ask, does Sense 5 XYZ?
People there are cool and helpful.
Plus - we have a small ton of Sense 5 tips built up over there in that forum since the time of the One launch.
Perfectly ok to post anything cool there back to here if it helps with this rom use, I should think. :)
Is anyone getting multiple texts inbound and outbound?
Since flashing r24 it's been happening to me. I've seen it before, purely Sprint network jitters, but figured I'd put this out there just in case.
Working as in should here.
So far anyway. :)
Could be a local provider issue.
Came from KitKat CM11 doing the selinux TWRP full wipe/reboot without any problems. First sense 5 ROM I've successfully booted. Good work captain.
Well, I am impressed with R24. All is working flawlessly! Love the speed that Sense now has.
On a side note, I was unable to dl Bullet proof, so I flashed Dirty Mac. So far, so good. Battery life is great, and when you turn up the clock, it screams. Just thought I would share that.
So far anyway. :)
Yeah, they've been turning more 4G towers on in the area. It's probably echos from that.
I'm going to update PRL and Profile again see if that clears it up. :)
