Thanks for sharing! I assume you tried it?
Uhhh...aha. No I did not. But it should work as it was tested on a Evo 3D.
I would make a backup before trying as well.![]()
There is a comment that says it didn't work on the 3d. Was just curious. Maybe I will try it in a bit.
Yeah but the 3rd comment is:
" Just FYI. I tried it on the Sprint EVO 3D and the replace failed (probably because Sprint puts the boot animation in /system/customize/resource and calls it "sprint_bootanimation.zip")"
I believe our bootanimation zip has htc before it.
