Help sense clock widget
does anyone know if i can get the sense time widget on my droid x. is there a look alike somewhere?
Yeah. Like the guy said before me, Beautiful Widgets. And there's also Weather + Toggle Widget, but Beautiful Widgets is by far my fav. :)
Try them both. See which you like best.
Thanks _inKredible_ this the best weather clock widget the other widgets like weather & toggle and beautifel widgets dont work so good if you refresh the weather they will be gone and if you want it get back you need to insttal the widget again... (that sucks)
So thanks for the apk file...
i tried downloading the fancy widget on the x .but iy say "cannot download.
the content is not supported on this phone.
thats even after i checked off unknown in settings under applications
Several of us have remarked that the Weather & Toggle Widget appears to be the most Sense-like of the weather and clock widgets. (On rainy days, you'll see the windshield wiper after clicking the weather on this widget.) :D
There are many skins, but the h7c clock and h7c weather skins are clones of the Sense clock. They can be downloaded from within the weather app by clicking on the weather portion of the widget and pressing the menu button and selecting "weather setting", select "widget skin wizard", "download skins from the server" (I think), then install those skins from the SD. These are not Market skins.
