Over the past 24 hours sense has force closed or reset on me around 3 times. I am wondering if anyone else has this problem. I am not running LP or home switcher so i am not sure what could be causing this.
That has happened to some people, not really sure what the problem is. Make sure you have all your updates I guess. Try shutting it off and pulling the battery for a little bit then put it back in, see if that helps.
its odd, the only thing i dont have updated is the my verizon app because i never use it, and bubble breaker, in which the newer version asks for permissions to my messages so i am not updating it. i will turn my phone off tonight to see if it helps.
Try a reboot, and also look into any apps or widgets you installed recently. When I first got my phone I installed the widget that makes an icon for hte web browser that looks ilke the chrome logo, and I got sense FC's multiple times per day until I removed it.
i haven't been having any problems today, it was weird that this happened yesterday after i was in a verizon store, its like they want my phone to die so i have to buy another one.
