Root sense UI skins?
H2342
Member
Is there any way that the Droid Eris can get those custom sense 2.0 skins like the thunderbolt can use?
the short answer is "no". at least not until an ambitious developer tries to port them over. i have seen comments that sense 2.0 will prolly not run very well on the eris.
there are not completely functional sense 1.0 froyo roms yet,so sense 2.0 roms dont seem likely to happen,unless it could work with 2.1. im not a sense fan,so i have no idea if 2.0/2.1 would work,or even if you could simply use the skins with sense 1.0.
i dont know if any of that helps you,but i dint want you to think your question had gone un-noticed :eek: ;)
