sensor and resolution problems with my VX570R
Dom83
Hello
I just got an Onda VX570R running Android 2.1 . There are two serious problems on it :
The Sensor :
The sensor works fine with the included game Labyrinth, but does not work at all in any other game I tried ! :( ( Duck, Hungry Shark, Hyperspace, Slimeball Speedway... ) It's like they don't detect the sensor...
I dont think the device is defective since the included game works... Maybe it has to be calibrated, but I don't find any way to. I downloaded sensor-test.apk and tried, and things look good to me. I tried Bubble but the bubble does not move at all, it stays stuck so I guess it does not detect the sensor at all.
The Resolution :
The other problem is about the resolution. It's 480x272 instead of usual 480x320. Many games flicker, they look like hesitating which resolution to scale to.... Some other games don't flicker but are cut. :(
Does anybody know what I should do with these problems ?
Or these may be just bugs Onda has to correct, I contacted them about it but they never answer when I contact them.
