I love this rom but I have a couple issues that are kind of annoying. When I make calls I can barely hear the person on the other end and also when I make calls my screen goes blank. Does anyone know any fixes for this?
I have been having another issue for a while. Airplane mode just randomnly turns on any ideas on anything I can do to keep this from happening?
When I turn my phone on, a weird screen with colored horizontal lines show up for a few seconds before the serendipity VII screen. Is that normal? If not, how can I fix it?
Thanks!
Thanks!
This is for Serendipity VII?
this same thing happened to me.When I turn my phone on, a weird screen with colored horizontal lines show up for a few seconds before the serendipity VII screen. Is that normal? If not, how can I fix it?
Thanks!
Installation:
1. Download this package.
2. Open Odin3 1.7.
3. Select the PDA, PHONE, CSC, and PIT files in their correct spots.
4. Connect phone in download mode. Use a USB port that's on your motherboard (the ones on the back of the computer). Use the Samsung USB cable.
5. Ensure that Auto-reboot and Re-Partition are both checked. These have a tendency to change after plugging the phone in, so double check them.
6. This is where the bootloader will be flashed, along with stock Gingerbread. Hit Start.
7. Allow the phone to boot.
8. Close Odin3, and open a fresh one. Select Reorient_Kernel_1.1 in the PDA box.
9. Reboot into download mode (adb reboot download, or hold Vol Down + Power).
10. Plug the phone into the computer.
11. MAKE SURE RE-PARTITION IS NOT CHECKED. If it is, you'll soft-brick and have to start over.
12. Flash the kernel (hit start). Allow the phone to reboot.
~IF YOU ARE CURRENTLY ON A SAMSUNG-BASED GINGERBREAD ROM WITH BOOTLOADERS (NOT CM or MIUI), START HERE~
13. Place the ROM .zip (You know, the one you downloaded from the giant link up there) onto the SD Card.
14. Reboot into Recovery (adb reboot recovery, or Vol Up + Power).
15. Flash ROM with CWM.
16. Enjoy!
Everytime I make a call, the screen turns off and I cant do anything... how do I make the screen come back on again?
Also, not sure if anybody else discovered this but when I rub the notification bar from left to right back and forth the screen brightness changes... is that an intentional built-in feature?
does anyone know of tethering works without having the tethering service from the provider?
There's no way to go from Serendipity 6 to Serendipity VII without having to restore apps via Titanium Backup, right?
