Root serendipity VII build 2.kernel 4.1(music player)
rana1
Hi , I was using stock 2.2 before and now I flashed serendipity VII build 2. kernel 4.1 .everything is alright. Calls are perfect ,bettery life is great. Everything is amaging without music player.I can't create any playlist in this one. I download one is for honeycomb. Installed and same problem with that too. I try some aps from serendipity kitchen (allshare, Google talk) never worked.
someone please light my dark ways. Thanks:confused:
You could find a new music player .apk from another ROM. I personally use the MIUI music player and it's great. But you need a file program that has read/write capabilities to be able to extract from a ROM and re-install.
