serial number missing after upgrade
So my tablet informed me that an upgrade is available and naturally I wanted to get newer version of the software - bad mistake. After upgrading the tablet has lost the registration number and I have no paper copy of the number, as I newer earlier even knew existance of such number.
So is there any place I could request a new serial number for my android tablet?
I don't think you can just ask for a new serial number. Serial numbers are intended to be SPECIFICALLY for that device. You don't just get a "new one".
If an update wiped the serial number, and its not physically on the device or box, your pretty much out of luck.
You can find your registration code at Settings-about device-certificate. It's a very long number hope this helps
