Help Serious Problem
FNFUP
Hi i got a telus milestone from usedottawa a couple months back and yesterday it just automatically restarted displayed the message
Bootloader 90.74
Err: A5,00,35,2F
Battery OK
OK to Program
i read a couple forums and saw this was a issue if the phone had been rooted.. i personally did not root the phone so does this mean the previous owner definately did or is this a fluke thing?
Also i tried all the step like flashing a sbf and such but when i flash the computer tells me "Phone Failed Inital Security Check HAB error 0x8D"
is this phone bricked ... what can i do ... I NEED HELP
Thanks in advance for your time.
I googled your error and it happens to other Motorola phones when you try to flash an SBF for a different phone. Which SBF are you trying to flash, where is the SBF from? Where did you get your phone, and who is your providor?
I just realized that you didn't tell us if you could get into recovery mode or not, if you can then you could try doing a factory reset.
Also did you receive the box that the Milestone came with? Just trying to confirm that we are dealing with a Telus Milestone.
As a final option and if you feel like going for broke, you could try updating your bootloader.
its a milestone as it a sim card phone but i couldnt get into recovery so im trying to find out how to update bootloader but i couldnt find the sbf
You can find the update for the bootloader on the same page you posted above.
