Root Serious Restore Problem
Is it possible that you switched your recovery from Clockwork to AmonRA? If so - you can only restore a nandroid backup made by the same recovery method.
In other words - if you did a backup while running Clockwork mod recovery and then switched your recovery to AmonRA - you can no longer restore the backups from before the switch. UNLESS you switch back to Clockwork to do the restore. Then of course you can switch back afterwards.
Jack
Jack
