ThrowingKnife
Okay there is a real problem with the update and if it doesn't finish downloading, it will brick. What exactly do I mean? Well I was downloading the update and pressed cancel. Then resumed it and it went into update mode. Then it said update failed and turned off. There seems to be a problem where it gets bricked with no power whatsoever. No amount of recovery mode will recover it. Be warned that updating can be dangerous and you should do so with caution. If the update fails it should reboot but that didn't happen for me. Looks like I'll have to stop at Best Buy tomorrow for a swap...
