Hey guys, sorry for the cliche first post, but believe me I have been searching and reading all night and day for a problem similar to mine.
I was running CM9 on my Droid 3 and was having trouble because my phone kept running in safe mode, which was causing some of my apps to not work, and when I turned safe mode off, it ran the stock droid OS, which I didn't want. Therefore, I manually turned my safestrap off (first mistake) so now I can't get into it. Alternatively, my volume down button doesn't seem to be working so I can't select AP Fastboot to flash my phone back to factory settings and eliminate all my woes. When I try to power my phone on manually, all it does is load me into the BP Flash screen, which to my understanding doesn't work (why did they put it in?). I've tried to press the down direction key and power to shortcut into AP Fastboot, as well as power button volume down, neither of which work. I can get into the screen with Normal boot, recovery, etc but cannot select anything, and it just goes to normal boot and proceeds to bootloop. Is there anything I can do in this predicament? Any help is much appreciated.
