Root Services.jar from ICS Leak
craley1
I'm looking for the "services.jar" from the leaked ICS rom. Can anyone provide a link or zip of this file? It should only be about 850 kB.
I believe I have one from the ICS Leak. I'll look through my files and if I don't find it I'll just redownload it for ya
Thanks but I'm not sure that's what I was looking for. There wasn't anything in that .jar other than the .yml file. There should be a tree structure with a crap-ton of folders and even more .smali files nested within. Also, the download shows only 300 Bytes.
Here is what I built from the CM9 source with D2A's device tree.
there would be a classes.dex file if the source was de-odexed and a meta-inf folder. the classes.dex file (services.odex) would be what you need to get the smali files. and you'd get that from baksmali
When I open megaghostgamer's services.jar with winrar, the only file in it is MANIFEST.MF located in the META-INF folder. When I decompress it with apktool, the only file in the generated folder is apktool.yml.
D2A is having a rough night. Do not, I repeat, do not flash the P930 version to your Spec. Also, at this point, I doubt you will find anyone that will upload the V7_5 tot file. Too many people bricked their phones trying to flash it, that putting it out back into the wild is just asinine.
oh.. thats why xda deleted it.... i c...
well the OTA was supposed to come, any day now, months ago...
geee... wonder why... thx!
