Root Set Cpu not working
Droid X 2.2 OTA Root. My SetCpu isn't working now. I have tried the following unstalling the app, reinstalling the app, clearing the cache, force stop. I can't get for setcpu to ask me for permission for SetCpu. Everytime I press Auto Recommend it just goes into a blank black screen. Relaunching the app does not solve it either.
Edit Unrooted my phone and rerooted my phone and reinstall setcpu same issue
Edit I have also removed the root and did a factory reset and then rooted but the same problem. Edit Added some logcat if anyone can understand them
Go into settings, apps, manage apps, click on the su app then clear data
Yes I have tried clearing the data, cache, reinstalling and uninstallin, rebooting the setcpu app and nothing works. But if i were to unroot and reset my phone to factory reset it would be safe from brick?
Did you try going into Superuser app on your phone and manually setting SetCPU to allow?
Yes I have gone into the SU App but I don't see how you can manually add an app. I don't see the option for adding anywhere.
Edit: I also just tried a Titanium Backup restoration from 10/6/10. I did both the app +data restoration. ON restarting my device finally asks me for permission and I'm able to see the SetCpu Icon on the Notification bar. This tells me that the device is working on the background but when launched all it shows is a blank black screen with no option at all.
