Help Set Up
Prso9
Hi, So I finally get the chance to transfer thing from my Xperia X10 to my Xperia S. There is 3 things I was wondering if anyone could help with.
Can I transfer my browser favourites somehow?
Can I transfer my txts?
Can I transfer any info I have saved in AK Notepad?
I can only answer your 3rd question, and as long as you add an account to AK it will synchronize with and android phone when you log into your account. Great app.
I don't think you can do the other two. But I stand to be corrected.
Hi Prso9, I have recently completed data migration from arc s to Xperia s. It may not be the best option available. If you are Still holding on to x10, you may depress long enough on your browser bookmark and select the option to share the link of each bookmark to your new phone via Bluetooth. You may then save the link as bookmarks on your new phone. In case you are using other browser like dolphin. Its easier, just copy the bookmark directory from your sd card and paste it to the new phone dolphin directory. You may then have the option to import old bookmarks from sd card. Hope it helps. Cheers.
In case anyone else needs to know how to do this.....
I signed into AK Notepad and was able to sync the notes that I had saved on my old phone.
Transferring my txts, I downloaded SMS Backup & Restore (created by Infolife LLC) on both phones, created a backup on my old phone. Connected both phones to my computer and copy and pasted the backup from my old phone to the new phone.
Hope this helps someone
