Root SetCPU and GB ROMS??
thanks for the quick reply! unfortunately, the update didn't fix the widget. temps don't seem to be refreshing after awhile. it works at first when you set the widget.... :confused: even tried setting it to refresh every 5 sec but will stop after awhile.
The basic idea here is that GB is far more aggressive at killing tasks in order to recoup memory for use with other applications than previous versions of Android. At least, this is my understanding of the situation.
As you know, a widget is (usually) constantly trying to update itself so that it can give you the best real time picture of what is going on in that application. If you have lots of services eating up your 'RAM', or else start multi-tasking heavily, GB will try to prioritize what you have running actively - and start killing off the passive stuff one by one.
I know that CM7 and PE5 both have the built in CPU governor, so SetCPU really is not needed, but neither have a widget to show such things on screen. It would be great if someone could add such a feature to either ROM - even adding it to the lockscreen would be of tremendous value (to me, anyway :p). Until that happens, though, you'll probably need to have to refresh your widget manually (if possible - otherwise a complete home restart may be required once the background SetCPU process gets killed and you manually restart it).
I know this was not a 'fix' per se - but I hope you now at least understand *why* it is happening.
