theyalltaken
I've done some searching and couldn't find a thread related to my issue. I'm new to overclocking. I'm using the Infected Eternity ROM and was experiencing a little lag. So, I did some reading on SetCPU and figured I'd give it a try.
I installed the program and set the scaling to lagfree: 1267 max and 245 min is currently what I'm running. The lag is gone but so is my network
Any ideas or helpful tips? Should I just uninstall?
Network finally came back. Coincidence.
Mods can delete this post.
