Root SetCPU installed
la sal
Android Expert
Installed SetCPU.
Under the Main tab it says: 600MHz-245MHz...this is flashing these two readings. Under it: scaling ondemand. Beneath that: 600 max 245 min.
Is it overclocked or do I need to set anything? I checked Set on Boot and everything looks like it was taken care by the SetCPU program. Just wanting to make sure.
Looks like I have everything set after watching a youtube video. I set my max and min for my screen off and temp > 50 degrees C.
You should go with 45c as it is the Max rating for your battery and anything over can cause all sorts of issues from charging problems to swelling and leaking.
