ral
Android Expert
I installed the new Blackout ICS ROM v.3.1.0
Issue with SetCPU (the free version posted here in XDA).
The default setting for this ROM is 1024 MHz with Performance as the Governor.
I tried changing the Governor from Performance to Ondemand. When I set it with SetCPU, the Ondemand governor takes over.
The change is reflected /sys/devices/system/cpu/cpu0/cpufreq/scaling governor.
On reboot, a notification pops up the SetCPU has set new values.
Unfortunately, after boot, verifying the /sys/devices/system/cpu/cpu0/cpufreq/scaling governor will show that it is set back to the Performance governor.
Was thinking of two options. One is to make SetCPU a system app and see if that works (virtuous and andrev are more stable when the OC Deamon is set as a system app).
The other is manually editing /sys/devices/system/cpu/cpu0/cpufreq/scaling governor
Am going out to dinner so I will do it when I get back.
If anybody has any strong objections, please post here
:smokingsomb:
