Help Setting for SD Card notification sound is missing
D
Deleted User
Guest
Let me start with the basics, i have a none branded/unlocked Desire with firmware version 2.10.405.2, now, there used to be an option in older firmware versions, how old i can't remeber, to enable a sound notification for SD Card events, such as unmounting, mounting, etc, but this option seems to have been removed, at least on my phone, could someone please take a look through thier phone settings and confirm if this option is there, or not, i used to enable this option when connecting to the PC so i would know when the SD Card had unmounted/mounted.
Bump,
Can anyone confirm the above, shurely there's someone out there with stock FW 2.10.405.2 that could check.
Is there someone that could check the settings to see if this option has gone or not, please.
Maybe you could change the title of the thread for a better response.
Perhaps mentioning the build number and that it is a request for someone to compare settings with you?
Maybe:
"Please compare settings on 2.10.405.2" or something?
Thanks danfrance, i've now changed the thread tittle, hope i get a response now, much appreciated.
Hmm. Only seems to have changed the title for the post rather than the thread itself
Unless thats just me
