It is as simple and intuitive once you know how.
Open the calender app -> select the date for the event -> tap to create new event -> enter relevant details -> scroll down to reminders -> tap the green + sign -> select any option for a reminder from the dropdown menu
@swayzak no you don't need duplicates. you can edit exist events from your google calender.
@hawker Am on the stock ROM and you can actually do this.
Select the date with the event on your calender app -> tap the event -> tap the options menu -> select edit -> scroll down to reminders -> change as you want and hit save
p.s. I can't post GB guide as I am on ICS but I recall the steps to be identical
I currently have no "events" stored in Google calendar - just "birthdays"(synced from Google contacts). There is no notification option available for these.
From what you are saying I will need to transfer all these birthdays manually to "events" in order to get notifications.
A "birthday" synced from google calender is an "event", every b'day or meeting or anniversary you put in there is an event.
In the screenshots I provided it was a birthday event only.
Are the options different in GB (perhaps I recalled wrong) ? Can you post screenies?
You the man Hawker, can expect this dedication from youI have just gone back over to GB to test. How thoughtful am I?![]()
I can confirm, for birthday events brought in from the contacts record, as I thought, you cannot set a reminder to them.
Well the option to remind on a birthday was certainly there on D4Rom. This is ICS (CM9 based) so its either an ICS or CM9 feature.
Going on what Forbidden is saying, it seems its an ICS feature.
