Help Setting up email for my school not working.
They call exchange "Corprate Sync". So...
Open the "messaging" app, hit the menu key and select Mange Accounts. Click add account and add a "CorporatevSync" account. Enter the info, the domain and username are on different lines, but the info you need is all there, and before you hit next, press the menu key and select setup manually so you can enter the server. The rest should b self explanatory, if not PM me
I'm about to fly out, so I'll upload some screen shots later today.
Good luck.
Since I am traveling and do not have a PC I am unable to upload a picture. However, here are the settings I would use if my email was james27007@txstate.edu
Corporate Sync...
Email: james27007@txstate.edu
Password: ******* :D
Domain: TXSTATE
Username: james27007
Server: bobcatmail.txstate.edu
Don't forget you need to hit the menu key and select setup manually to get the server option. If this works, please let me know.
