Help Setting up my phone
zinda
So I don't want to open new threads but I have a few general questions and for some reason the search doesn't work for me. The page just sticks there and doesn't go anywhere.
Anyways, I have a lot of pictures and videos from my old phone and I was wondering where I should drag them on the SD card. Also how do I make folders so I can organize them properly?
What is the best backup application? I especially want to save my texts and be able to restore them. How long do these droid phones save text? I would like it to do it indefinetely.
How do I transfer my contact list from phone to the car?
What is the quality of watching a movie off the incredible on the tv using the tv out cable? If I download a movie from the internet and convert it will it play properly?
It depends if you're rooting. If you are, then ClockworkMod saves a back up file of your phone as it is. Basically a screenshot of your phone at that current time. I'm not sure if you can use Titanium Backup without being rooted but it's also a great backup application.
Do both of them save texts and restore them?
I am rooted by the way
