Help setting wallpaper options
carthorse
When i first set my home screen wallpaper, it asked me if i wanted it to also set the lock screen wallpaper. There was a checkbox that said something like, "Remember this setting". I accidentally checked it...now everytime i set my home screen wallpaper, the lock screen gets set as well.
Where can i find this setting and change it? I can't find it for the life of me.
Thanks
Go to menu>settings>applications and select all apps. Then scroll to TwWallpaperChooser, tap in it and select clear defaults. The next time you change your wallpaper it will prompt you as before.
Thanks, i found the app TwWallpaperChooser, but the "clear defaults" option is greyed out and it says "no defaults set". The only option i have is "disable".
Hmm, I wonder if it's a default setting of TWLauncher? That's touchwiz in general. Be advised, if you clear those defaults you'll be getting a lot of menu prompts until you reset them.
Ok, tried that, it reset my icons, but it didn't prompt me when i set the home screen wallpaper again.
What else can I try?
Thanks
Thanks, i saw that setting, but i usually set the wall paper/ lock screen from my gallery app. All of a sudden a light went off, and i reset the settings on the gallery app. This reverted my settings so it prompted me again.
Thanks!!
