scottmbolt Android Enthusiast Aug 3, 2010 #1 Is there anyway to add the list of notifications to the list of ringtones, so that if I wanted to make a notification option a ringtone, I could. Thanks!
V425 Android Enthusiast Aug 3, 2010 #2 you should be able to just copy and paste from one folder to the other using a file manager app like Astro or by mounting to your computer.
Kelmar Done by choice Aug 3, 2010 #3 Are you rooted? Use root explorer (or similar) to copy them to you ringtone folder on the SD card. If not, are you looking for any tone specifically?
