Help Setup Help - Droid to Inc2
maryhitt
I have been using the original Verizon Motorola Droid since November 2009, when it first came out. I recently bought the Incredible 2, have charged it but have not yet activiated it. On the Droid, I have been using Gmail for my mail, calendar etc. The first thing I noticed in the setup instructions was to backup my Contacts using Backup Assistant. However, Backup Assistant is not available for the Motorola Droid. Since I already have my contacts saved in my Gmail account, is this step necessary?
How do I transfer the data and apps from my Droid to my Incredible? I assume that anything I purchased on the Android Market can be downloaded again, but what about the data that goes with those apps. Some of the apps I use have the ability to backup online, but not all apps have this.
I have an app called MyBackup Pro on the Droid, and it allows me to backup online, to the SD card, or to both. If I backup the data to the SD card, can i just transfer this SD card to the Incredible and recover the data there (once I have re-installed the apps)?
Any other startup suggestions? Anything I should watch out for? Any apps that you highly recommend?
Thanks in advance for your help.
I can help with a few of those questions. All your Gmail contacts will sync when you sign in on the Dinc II. All of your paid apps from the Market will show up. I had to find the free ones again.
Wish I would have looked into transferring my game saves. Guess I'll just replay Angry Birds!
