Help Sgs2 cache clearance
Hi everyone,
I have sgs2 int. Unrooted phone. I have next problem. Storage space running out on my device. I have tried everything to keep up with free memory for apps. But I have encountered with next problem.when cleaning cache for each app,it rather decreasing my memory in app device storage. I have tried also several apps in play store but it giving same effect.
I thought that cache cleaning rather suppose to increase memory. Correct me if I'm wrong. Thanks.
Hi mate,
Have you tried cleaning the cache by powering off your phone, press and hold volume up, power and home. You should see the green android man and after a min or so of loading a list of options one of which is to clean cache. Select it by using the volume up/down button to highlight and then the power button to select. Once cleared the cache you can then re boot the system. Hope this helps.
