reach2venug
Hello All
I buyed SGS2 from dubai and when I charge it for here, its charging for a quite a long time and after that i get an battery with yellow triangle on it. I tried to change the battery and charge it again. I landed up on the same problem. So when the battery has some power the mobile works fine and when it comes down and if you put it in charge - the battery is not getting charged. I tried to put the battery in another SGS2 and its charging properly.
There is no issue with the charger and power regulations
What's wrong with my device - are there any h/w issue ? Any firmware issue ?
Since i buyed outside India - Samsung Service support said there is no warranty on it. They will charge if its h/w issue and for replacement of mother board the charge 10k
Its just 10 days old and its running Andriod 2.3 and the default firmware that comes from factory setting.
Pls help me out on what needs to be done
Thanks
Thanks
