Help SGS2 inverted screen.
pc1staid
Hi, please excuse me if this has been answered before, but when i put in inverted screen I get a lot of results showing inverted colours ( negative mode) which isn't the issue i have got.
The problem has been resolved as such by fitting a 2nd new screen but just looking for pointers.
Customer bought in his s2 with a cracked screen. I replaced it with another and when powered on the display is upside down with the digitizer working the right way up. replaced with another unit and works perfectly. my wife has an s2 so the unit i had the problem with, i fitted it to hers and it works perfectly.
I have seen a couple of you tube video's showing the same issue but no resolves.
any ideas anyone?
Thanks in advance.
Marc
