I experienced this on 1.0.4. Are you on that?
No I'm in 1.05 I even flash shabby fix and it still fails some of them hang
what fix?
Well maybe I miss understood the real build for an mms fixed a couple of days ago lol my bad
Is was reading 4.1.2 has side bar and multi window feature, does 105 have both of these?
Addons:
Reboot menu
Xposed mods
Modded weather lockscreen
Ink effect (1.0.4)
Themes:
Metropolitan Theme(1.0.4)
Metrojam Theme (1.0.4)
in case you didnt notice this list seems fairly dominated by Arocker, be sure to give him a bunch of thanks for making this rom even better![]()
Downloads
Latest version:
Version 1.0.5
Latest FULL rom (as in start here if you are joining us
Version 1.0.5
One more thing lol. What's the difference between these 2?
I'm on 1.0.5 but it still says 4.1.1, does that even matter? just curious..
I'm having a lot of bugs on 1.05 I don't know if I flashed it correctly. I did my normal process (backup, wipe, flash, reboot) maybe I need to wipe cache and dalvik after? There's no straight up instructions on this thread. Gallery force closes, rom setting force closes
Downloads
Latest version:
Version 1.0.5
Version 1.0.5
Does anyone know the difference between these 2?
Found a popup browser apk that works great in metropolis: http://androidforums.com/metropcs-g...izable-popup-browser-works-in-metropolis.html
Correct me if I'm wrong, but I believe the Note2 & S3 are the same except for size. So anything that can be taken from the Note2 can be used on the S3. I know the camera works on ours, so why not anything else?
Chemistry is good but needs a kernel that is a battery killer IMHO. Plus has a ton of features built in apps I don't care for.why waste time when you can just get chemistry?
Hey Shabby, you forgot an addon. The note2 camera & gallery from post #178.
Downloads
Latest version:
Version 1.0.5
Version 1.0.5
nothing i just have them listed twice so that when i do update i only have to change one link etc
dont like the rom then dont use it, dont post in the thread either![]()
thats just disrespectful shabby has put in alot of man hours for free just to give back to this community. to be honest ive never used anything made for us cellular and i refuse to use such things. i have my reasons. if you prefer using stuff made for another phone else where thats great we hope you continue to enjoy it. Ya wanted stock jellybean rom for metro ya got it!why waste time when you can just get chemistry?
