[SGS3-R530M] Metropolis Rom [4.3 Touchwiz]
A couple more
This....is.....sexyness!!!!
This is my Metropolis Setup... :p:p:p:p:p
Dumb question how do I turn on the multi-window option? I don't see the option to tun it on on the "Display" menu. I looked around but I didnt see anything on it.
hey guys do u know why i cant access old codes that worked on ics the only code tht works is the one to enable hidden menu and thats it i cant access *#0*# which is the test settings to see if everything is working on the phone and also the *#0011# which is to view the lte mhz
I couldn't find a post on this, so I did some digging and experimenting. When I got the Jelly Bean update on my S3 from Verizon it killed my Wifi tether. For the past week I've been without, and today I figured it out!
To get Wifi Tether working on your Rooted Verizon Samsung Galaxy S3:
1. Uninstall your current version of Wifi Tether
2. Seach for, download, and install "Wifi Tether - TrevE Mod"
3. Open the app, and select "Samsung Galaxy Nexus (CDMA/LTE)" as your device
4. Select "Hostpd (master)" as your Setup-Method
5. START WIFI! ... you should be good to go.
Note: I had some trouble with encryption, so I left that disabled. However, I found success in changing the SSID and enabling Access Control.
Enjoy!
This not is my work
Gonna try this for the first time... Hows this been running (question to those who've been running it since day 1).
Also are gapps included? Sorry haven't been on stock in.....yea:-/ a while..
I tried some 4.2 roms and a couple minor bugs that were major problems turned me off...So I had to come back home to the flawlessness lol....Quick questions tho I noticed in edge's screnshots he has a colored statusbar how? also how do you get multi-window to work? I saw a post that said hold the back button for 5 seconds but nothing happened except the sidebar came out.
that is the multiview.
Now just hold on any app and drag it to the side of the screen you want it to be on (Top or bottom)
i wanted to fill everyone in on my situation.
wife and i got into a pretty big fight and she is concerned im not spending enough time with my daughter, and to be honest shes right. unfortunatly the only things i do are play some games, do android stuff, play with my daughter and clean the house. can you guess which two are getting a time cut?
this isnt long term and ill still be popping around, just cant promis eill ahve teh time to dedicate like i did before. im not going anywhere or to another phone just trying to take care of some personal issues. im sorry if this upsets anyone but its what i have to do.
Tmi..... Thnx though
No prob shabby family first I respect that man
Take you time family is more important
So. .... I flashed this last night for the first time since like 1.0.3. And well I baked up my set up before i factory reset with TB pro. Now when i open up titanium backup none of my backups are there:(
That's something ya gotta watch with TB on JB - it will store your backups on the Internal by default... you need to go into preferences and make it save to your External card instead. It must be a JB thing, because I never had that problem with TB on ICS - it used to save to the external by default
On another note. What do you mean when you say baked up your rom
Family first shabby take care I have kids too and a wife I can relate to that we will see you later bud :thumbup:
