2 28jhuz Newbie Dec 20, 2013 #1 Settings>Network connections>More networks>Mobile networks>Mobile data>(The 4G LTE Indicator here is missing) Do you have the same issues with this problem? How to fix this problem? TIA
M MiSTER31 Lurker Feb 12, 2014 #2 28jhuz said: Settings>Network connections>More networks>Mobile networks>Mobile data>(The 4G LTE Indicator here is missing) Do you have the same issues with this problem? How to fix this problem? TIA Click to expand... had the same problem.. you can fix it from this guide. galaxys4ltefix dot blogspot dot com
E Ekendra Newbie Feb 14, 2014 #3 MiSTER31 said: had the same problem.. you can fix it from this guide. galaxys4ltefix dot blogspot dot com Click to expand... Method 1 worked with the Samsung Galaxy S4 Active i9295. Thank you VERY MUCH MISTER31 Regards Ekendra
