Help SGT7:How do I uninstall Gingerbread? It sucks.
d4005
Since installing 2.3.3 on my sgt7, it's become so slow it's almost unusable. I'm on the verge of throwing the thing away. I'll be playing a game for example, press the home key and I see the desktop (after a slower than usual response) then I'm sat there waiting second after second after second for the icons to show up. Sometimes they don't, and I have to swipe left/right to another page of my desktop and back. Other times I'll press a key and after a second of no apparent response to it, I'll press it again (while shouting at it) and then both key-presses are acknowledged. Not very useful when the key I pressed is the shift key, and my second press cancels it.
Gingerbread has totally taken all the joy out of using my SGT7. If I don't go back to Froyo soon then I'm likely to throw it against the wall soon.
I couldn't find how to uninstall 2.3.3 via Kies, and don't see it in the Android menus either.
I'd happily reset it to factory settings and re-install every single app to get back to Froyo right now.
As far as I know once you do an OS update whether it's a phone or tab then even if you factory reset you would still have that new OS on there.
is dis TRUE....'m about 2 UPGRADE ma SGT7 to gingerbread ... wil dis advisable? the probs is oly wit GB 2.3.3 or even in 2.3? plzzz help me ....
is dis TRUE....i heard GB 2.3.3 sucks n slows down the system???? :rolleyes:'m about 2 UPGRADE ma SGT7 to gingerbread ... wil dis advisable? the probs is oly wit GB 2.3.3 or even in 2.3? plzzz help me ....
:eek:
