Root shadowrom help
inline6power
i am just as pleased as all get out with this rom but i have 2 problems.
#1 everytime i go into settings and click on sound it force closes everytime so i cant do anything with ringtones and so on
#2 is there a way to change or add to the dialer so that when i start typing numbers, contacts will start showing up like on old dialers? i have a HUGE contact list and it seems that i can only use favorites to find people fast. really wish i could start using the numbers and their corralating letters to find contacts.
if their is a way to fix either of my problems i greatly appreciate it .
I don't have an answer for # 1 but #2 is easy. Download "Dialer One" If you like the launcher that is included with the ROM then just put a short cut to Dialer One on the homescreen or download ADW or Launcher Pro and you can put Dialer One in place of the stock dialer it has that feature and a lot of other really great ones.
I find that ShadowROM ran better with ADW and LauncherPro inplace of the stocker Launcher.
Give it a try
