Help Sharing calendars... Impossible or what?!?
Sirling
Ok, I have spent hours to find a solution, but there seems to be a dead end. I give it a last chance...
I want to share caledars with the rest of the family. I'm on Android (HTC Dersire HD) with exchange server 2003. The rest of the family is on iPhone also exchange. I find that Google Calendar works well for sharing so I am aiming for that choice.
But, how do I sync my Work -> Exchange -> HTC to my PC or directly to Google calendar?!? This must be possible or!?!
Best regards /Fredrik
well, you can try this
export your exchange calender in csv format or format readable by google calender (check that first)
then create a new calender in google web, and import this file into that calender
once imported you can then share that google calender to anyone
