Help Shortcut in waiting mode
Tigran
Can I add a shortcut in waiting mode to section in settings, for example "Use packet data" in Mobile network settings, and how?
Press and hold on home screen and menu will pop up.
Select widget from that menu.
Another menu will pop up and then select power control from that
You are done
Thank you varun.chitre15 for your answer, but I want to add especially the section "Mobile networks", and in the way you have written, I can't. Can you help me?
See this is blank screen
Press and hold on screen then this will appear
Select widget then this will appear then select power control as in the list
Then at last the widget will appear in this way.
Now you can turn on or off anything.
Hit thanks if helped
