shortcut or widget to battery usage?
amdrider
is there any way to get a shortcut, app or widget on the home screen that takes you to the battery usage list?
its a pain to do settings, about, battery use, ....
thanks!
I Downloaded Battery Widget because I like to hide my notification bar, but would like to see my battery meter. This widget is perfect! Its very small... show percentage and bars, also fits most anywhere when using many widgets on one screen.
