Very very happy with my new zoom!!! However....one thing is bugging me. When you install a new app it automagically creates a shortcut on the home screen. Is there any way to turn this particular feature off??
yes up top on the right side of the screen there is an option to uncheck this. i think its when you are in the market. go to the market, look over to the top right, should be some options there, touch it and you should see "create shortcuts..." or some such...
Ahh yes there it is...I knew it was some button I was missing. To be more precise for others who read this it has to do with the menu button adjusting based on what screen you're looking at...even IN some apps. For this particular toggle go to the market and click on my apps, THEN click the menu button in the top right corner. Thanks for the help!!
