Root Should I clear delvik cache and cache regularly?
rbtrucking
I noticed the other day after I cleared my delvic cache and cache my battery life was drastically improved but then as a couple days went by it seemed to deteriorate. It seems whenever I clear the delvik and the cache I get much better battery life. Should I do it regularly, do any of you?
Yes. I clear mine every couple of days. Also, if you haven't already Calibrate your battery. You don't have to do this multiple times while on the same ROM, just after flashing a new ROM. This will also help your battery.
alright thanks. I heard about callibrating the battery but I never did it. I will do it right now, appreciate it!
Just to be sure in my recovery I dont see any callibrate battery option. Is it the same as wiping battery stats? Thats the only battery option I see.
I gave you a link in the post you replied to referencing an app that will do it for you. Essentially you *can* just delete battery stats BUT there are other steps involved when calibrating your battery. I recommend just downloading the app and follow its' instructions.
