Should I Download Flash?
hero1908
I have an Orange branded Desire running Froyo, I believe Flash is on it but some have commented that they have downloaded Flash from the Android Market as it's available.
My question is, should I download it from the market? If Flash is updated I don't think I can get the update as mine came with the ROM and not the Android Market.
Thanks in advance.
I did but uninstalled ,it is a whopping 12mb of your phone memory ,the original flash is embedded in the rom ,so the update doesn`t update, it gets used instead ,i think ,but a true update should replace the orginal .
Yea I wouldn't bother unless your not worried about loosing the 12mb of space, I un-installed as soon as I saw the size.:rolleyes:
