Help Should I wait...
Personally, I would (and I am) waiting...
Just seems like work to do it than un-do it to get the OTA...
On top of that, once ICS does drop, the ROM's will just get better..
Lego
Personally, I would (and I am) wait...
Lego
Only concern I have with that approach is that the OTA may break root. It's happened in the past.
If you're wanting the best of all worlds, what I would do is root now and then when the OTA does come out, wait a day or two for the devs to release a ROM based on the OTA. That way you're covered for any situation.
I recommend this:thumbup:
