Show usage?
Hi everyone, Im a newbie to these forums so please dont be mean:p
Ive looked around and cant see the answer to my question.
Is there a way to see how much data you have used? and reset it every month?
Im coming from a iPhone to the desire soon and would like to know :) as I have only 500mb off o2.
Thanks in advance
Tom.
Stolen from Lekky's post
HTC Desire Tips & Tricks [READ ME]
*stickied on the main "HTC Desire" Sub forum*
3G WatchDog
You can use this application to keep a monitor on your mobile internet usage. Use this to make sure you never go over your allowance!
Hope that helps you :)
when I click on the link it says page not found:( but thanks anyway, so is there like a app or something you can get off the marketplace?
There's also a program called 'stats' which measure's all your data/mms/sms/calls/wif/mobile data etc.
Worth looking at several of the same type to see which one you prefer ;)
Thanks for the tip, now running 3G watchdog for quick reference for data usage, and stats as well for a more comprehensive check on my phone usage!
Check out Network Monitor too.
It gives you nice graphs of your Mobile/Wifi usage per hour/day.week/month, :D
